Fuel Sending unit?
Old Mar 3, 2012 | 04:03 AM
77D150's Avatar
Question Fuel Sending unit?
Anyone possibly know where to locate a sending unit for my 1977 Dodge D150 short box, mid mount tank, on the frame? Seem to be having a heck of a time finding one,was kinda surprised it was an issue to try to get one. New, or used in good condition would work, not real picky, just trying to get this truck on the road..... Thanks in advance.
Old Mar 3, 2012 | 07:57 AM
samuelcosmo76's Avatar
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product__22972253-P_N3340C_P|GRP2032____?zoneAssigned=1
Heads up, I replaced mine, and my gauge reads empty when i have half a tank...
Old Mar 3, 2012 | 02:03 PM
77D150's Avatar
Ok , so how about I rephrase this question..... Can anyone tell me what years and models will interchange with my 1977 Dodge D150 shortbox, frame, mid mount tank sending unit. If I have this information it will be much easier to locate a unit. Several local yards have a sender, but none seem to have the same info about the interchange. Thanks again all!
Old Mar 3, 2012 | 04:11 PM
77D150's Avatar
74-80 Dodge truck fuel sending unit #4240277
Im withdrawing the question as I have located a part number for the correct part from the factory, The number I have come up with is
MOPAR PART # 4240277
74-80 fuel sender for tanks mounted on the frame, mid body of the truck.
They are available NOS, or various other outlets, run about 100-175$ depanding on where you can find them, Hope this helps others out as well.
Old Jul 21, 2012 | 05:51 PM
rearl9's Avatar
Arrow
In order to fix your guage problem, you have to take the old sender apart and remove the resister, it slides out of the plastic float mechanism and cut the wire. Install it on the new sender and solder or use a solderless terminal to connect the wire. had the same problem, the new senders dont come with the right resister. This drove me nuts for weeks !
Old Jul 21, 2012 | 07:23 PM
rearl9's Avatar
PS I bought the new sender for my 86 from a dodge dealer last year ! It was the only place that had it new !
Aspen
Aug 31, 2009 10:28 PM
Evnas
Apr 12, 2009 06:13 PM
mopar nate
Jan 25, 2009 09:12 AM
nailbender
Oct 9, 2008 06:47 AM
64fury
Jun 16, 2008 12:40 PM
