Hard turning cranckshaft when engine is Hot (mopar 440)
Old Aug 14, 2018 | 03:40 AM
Ante Leko's Avatar
Angry Hard turning cranckshaft when engine is Hot (mopar 440)
HI, i hava done restauration of jensen interceptor mk3, whole car, and mopar 440 engine is rebuild with new pistons, rings, bearings, new heads, valves, whole new gaskets, new MSD distributor, edelbrock 1407 carburetor, water pump, fuel pump and MSD ignition coil,. ignition timing is set to 10° BFTDC, and it goes with vacum to 36° like in instructions of MSD. the car start and crank fine when is cold. but when it worms up, when i shutdown the car, and i want again to fire up, the crankcshact is crancking realy slow, sometimes wont fire up until its cold. And also when car is worm temp is 90° Celsius, and the engine has no power, i thinking mechanical fuel pump is bad, so when it worms up, mechanical pump dont deliver so many fuel so engine working with low fuell. what do you think the problem is with fuel and hard start? thanks
i have a video file:
https://streamable.com/y7iqw
Old Aug 14, 2018 | 04:46 AM
I’d be checking all the battery cables to starter, heat could loosen them and a heat soaked starter can slow down if weak and going bad.
Old Aug 14, 2018 | 06:40 AM
Ante Leko's Avatar
yes,its problem with cables to starter, when i rebuild engine i tighten starter positive cable, somehow now is loosen probably of heating as you mentioned, now is crancking fine. Now just engine has no power when is worm, i set timing, when i press gas pedal all the way down car start to die. Any suggestions?
Old Aug 14, 2018 | 06:44 AM
Archer's Avatar
A -
When the car is hot (and off), pull the air cleaner and manually operate the throttle.
See if A. any fuel comes out of the squirters and B how many times moving the throttle gives you a squirt.
A hot engine might be boiling off fuel in the bowls or lines.
Just a guess.
Old Aug 14, 2018 | 07:16 AM
Ante Leko's Avatar
When i press throotle, pump are spreading fuel, i dont see any kind of boiling. But now also i tighten starter cables, and still is sloww crancking when is hot. Dont know how to solve this
Old Aug 14, 2018 | 09:30 AM
Check timing
it could be the starter is bad.
Johndeedon
Sep 26, 2018 07:47 PM
hkestes
Sep 7, 2018 08:51 PM
64Imperial
Oct 18, 2016 05:07 PM
xjonathanx
Jan 29, 2010 08:56 AM
Steve Schmidt
Jun 21, 2009 05:51 AM
