Head question (casting numbers etc)
Old Jan 6, 2012 | 06:25 PM
hizen's Avatar
Really bad at this kind of thing with casting numbers, I have been trying to figure them out for years and can NEVER match my stuff up with the charts found online.
(4027596)
came off of a motor that was in a 77 powerwagon.
Thank you in advance.
Old Jan 6, 2012 | 09:27 PM
They came on 77 to 80 something 360's and some say HP 318's. They are not the swirl port or closed chambered heads but there was alot of back and forth arguements about them. Most said put some larger valves in them, port them some and you will have a good head. Note the smog holes. I had them on some cast 308 heads. Drilled them and tapped them and installed a set screw to block them off.
Old Jan 6, 2012 | 09:30 PM
hizen's Avatar
they worth anything? I am new to the Mopar world and and parting out the drivetrain of a truck I have. IE, motor, transmision.
Old Jan 6, 2012 | 10:31 PM
78doubleR's Avatar
if their from a 360 they will have 1.88 and 1.60 valves. 318 heads have 1.78 and 1.50.
Old Jan 7, 2012 | 07:59 PM
hizen's Avatar
They are off of a 360. I took them off and was going to rebuild this motor but the cost of doing the valvetrain the way I want is ridiculous. So I am trying to part it out to gather funds to do a motor swap, not really sure on motor yet.
D.j. Kellogg
Mar 19, 2013 10:43 AM
Leem
Aug 31, 2010 07:47 AM
henryj
Dec 19, 2009 09:21 AM
Stauff73
Oct 19, 2009 02:23 PM
darkcrow
Feb 1, 2009 06:51 AM
