header size
Old Mar 13, 2012 | 05:35 AM
duster sweden's Avatar
header size
very hot la 360 tti step, hooker 1.3/4 or 1.7/8 ?
Old Mar 17, 2012 | 12:56 PM
PK1's Avatar
PK1
As in max top end HP over 6000rpm? Biggest you can find. 1.7/8
Old Mar 17, 2012 | 06:12 PM
Archer's Avatar
ds -
Define "very hot", as in HP and max rpm, race only, street only or a little of both.
You won't get any advantage going over 1 3/4" on a small block up to 6 - 6.5K rpm and 1 5/8" is more common for a street rig.
Even a mild/moderate 440 will do just fine with 1 7/8" primaries.
Old Mar 17, 2012 | 07:19 PM
I ran the TTI 1 3/4" step headers on a hotter 340 roller motor and it would sit you back in the seat when you hit WOT.
Old Mar 17, 2012 | 08:19 PM
PK1's Avatar
PK1
Brememeric is correct on the size of the headers for his old ride and why they worked so well.
When you do the math for flow vs cross section assuming 18ga pipe you get:
A hot 340, assuming peak torque at 4500, specs a 1.76 pipe to have no back pressure in the header. back pressure in the exhaust is different but design should have non in the header. So his sizing was spot on.
A hot or "MAX" 360, assuming peak torque at 5000 ( we'll bump torque peak assuming you are using the 295XE cam you posted about before) and that 360 specs to a 1.90 pipe (thats why they make 1 7/8 pipes). Add a 150 shot of nitrous and you need a 2.07 to be restriction free in the header. Get out the tig welder baby!! So custom headers or you have restriction in the system.
Any 440 with a 1.75 has restriction at 3375rpm. So if peak torque is designed to be in after that your pipes are working against you.
A text book example of why headers really wake up a some motors with exhaust manifolds.
Old Mar 18, 2012 | 01:52 PM
have a cc xe295hl (not used) but i want lunatis woodoo mec,,60442 instead with my ported edel heads (guide cut down a litlle), junior singel plane and holley 850, 4000 stall with big cooler and dual big fan, 3.91 (next 4.33) this summer (engines list before) , the car are more a strip but drives on ouer wekeend racers.
Old Sep 17, 2012 | 05:44 PM
start my 360 up and test drive..run like he*l.. but one thing is that my elec' pump dont have a chance to deliver all fuel. Go to use one pump near the fuel cell tank and two beside the engine. Have a new mek' carter pump that should deliver up to 500hp, the quest, can this mek pump only and no more do the job??
bully62
Jan 21, 2015 05:37 PM
bgreene30
Sep 1, 2008 01:40 PM
Large Block
Mar 19, 2008 02:56 PM
bgreene30
Nov 23, 2007 09:08 PM
bgreene30
Nov 17, 2007 10:39 PM
