Hedman Headers 78030
Old 06-30-2013, 06:42 PM
mrzods13's Avatar
Looking at these for my 68 Newport. Summit and Jegs both have them for $159 shipped. Full pipe headers comes with bolts and gaskets. Just have to modify the shift linkage possibly. Any input or opinions or anyone who has a newport that installed these would greatly be appreciated.
Old 06-30-2013, 08:55 PM
inri's Avatar
For just a stock type engine they should be ok. BUT, depending on your engine hp and what you want to do (stockish cruiser or street/strip) you could get much better headers that will increase the exhaust flow and free of much more hp, sometimes in the neighborhood of 25 hp or so.
mrzods13 (07-01-2013)
Old 06-30-2013, 09:49 PM
Kern Dog's Avatar
These headers work but there are drawbacks. They have clearance problems with the steering linkage and column automatic linkage. If you are willing to modify a few things to get these to work, they are an okay value.
Old 07-01-2013, 05:03 AM
Hedman Header's steel headers are an "ok" header. I had a set on a J10 and they rusted within a year but were still sealed. I had some issues with getting them to seal when installed too.
Depending on how you drive your Newport, I'd keep looking into another set of headers. Long tube headers are great for motors that make power in the mid to higher RPM range (5500+). Most people when driving on the road and highways never see this RPM range (unless they are street racing which we don't like hearing about). A set of shorties will help create power from idle to ~5500RPM. This is great for most people with mostly stock motors. You can add an intake and carb later on they should work well together assuming you get an intake that creates power in that RPM range.
Old 07-01-2013, 05:22 PM
mrzods13's Avatar
I did buy them I got them for 138.99 shipped from summit. I could always switch it up down the road.
Old 07-01-2013, 05:26 PM
mrzods13's Avatar
I have the 383 2bbl.
Old 07-01-2013, 05:28 PM
Kern Dog's Avatar
One thing Hedman offers is a superior collector connection. Some use a ball and socket collector that uses no gaskets. They allow some small degree of MISalignment and STILL seal well. I'm not sure if all of their headers are this way. Other manufacturers should offer this feature.
mrzods13 (07-10-2013)
Old 07-01-2013, 07:08 PM
inri's Avatar
Mrzods,
I too had a pair of similar headman headers on my *ahem* '69 GTO. The black paint will fade pretty quickly and the will look much older than they are. I had not leak issues or anything else. If you want them to keep looking nice you may want to have them protected (high thermal coating). But that alone would cost more than the headers...
mrzods13 (07-02-2013)
Old 07-02-2013, 06:27 AM
mrzods13's Avatar
Mrzods,
I will probably coat them with a high heat ceramic spray to add extra protection. I am on a budget so thermal coating is out.
Old 07-04-2013, 06:13 AM
Strip the headers first. If you coat them before installing them without first striping them, the paint under the coating will still want to flake off causing the coating to flake off.
Old 07-04-2013, 05:21 PM
Kern Dog's Avatar
Good advice here ^^^^/
Another tidbit: Spray 3 thin coats of paint rather than 2 thick coats. The paint only has to be thick enough to cover and protect. The paint is more likely to flake off if it is too thick than if it is too thin.
Old 07-06-2013, 07:11 AM
pro-tech's Avatar
I sand blasted the pipes then panted them with what you are saying high heat ceramic paint and when you first start it just let it idle for a while and let it smoke/season the paint. The paint holds up very well and looks great. I had no issues with fit up either on my 1972 Duster 360 The collector ball sockets are great. Good luck there worth the money.
Old 07-09-2013, 02:57 AM
mrzods13's Avatar
What kind of mods so I have an idea.
Old 07-09-2013, 07:54 AM
Drag Pak's Avatar
Sandblast first as mentioned, and then thoroughly dry them immediately before painting with a heat gun. You will be surprised at how wet the bare metal becomes from atmospheric moisture.
Old 07-09-2013, 10:59 AM
Kern Dog's Avatar
In some cases, you'll need to dent a tube or two to get adequate clearance from the header to the steering box. Some designs also run close to the torsion bar or shift linkage.
I am more familiar with the 78050 pipes. Those require different spark plug boot ends on cylinders 5 and 7 because of the routing of the header tube there.
somkeone
09-26-2021 12:08 PM
my1965dartgt
09-01-2008 01:45 PM
J Dog
06-26-2008 07:10 AM
thekinzuakid247
01-31-2007 06:58 PM
my1965dartgt
09-28-2006 06:51 AM
Quick Reply: Hedman Headers 78030
