ideas for 440 6 pack
Old May 22, 2013 | 06:35 PM
383mopar's Avatar
440 6 pack
i was just wondering if any of you had any 440 6 pack engine combos that made 500+ to the wheels, using factory heads. i"m trying to get some ideas for my build.
Old May 23, 2013 | 06:15 PM
deadkelly's Avatar
what are you thinking about building mate ? & does it have to be a 6 pack ? b or r/b engine . what heads ect . 80% street or all out race ? 540cid,indy big easy heads , or any of the good alloy heads cnc'd & big roller . big that's what it comes down to the rest is easy just .
Old May 23, 2013 | 08:46 PM
Moparbob's Avatar
I just finished a "resto" style 440 6 pack Engine for a Customer, nothing fancy.
Other than a 274H Hydraulic Flat Tappet Cam, a good rebuild on the 906 Heads W/stock Valves, and some better Rockers Arms, ARP Rod Bolts, thats it..thats all.
Dyno'd at 440HP, but with 510 Ft/lbs Torque
but,
that was NOT a surprise through the restrictive Factory HP Exhaust Manifolds and 2 1/4" Exhaust Pipes.
Let me know and I will post up the Dyno Sheet.
Old May 26, 2013 | 06:45 PM
383mopar's Avatar
I have a 69 440, that's gonna be bored 60 over, and I was thinking about doing a mild stroke. I have 906 heads that I'm going to get some port work on. The car is gonna be street/strip and yes it does have to be a six pack.
Old May 26, 2013 | 07:13 PM
You'll have a tough time getting to 600 crank HP with stock iron heads, they will be the one thing holding you back.
Old May 27, 2013 | 08:07 PM
inri's Avatar
Agree. The stock heads can make power, with proper work, but you can buy much better aluminum heads that can make that same power out of the box; pre-porting/polishing. And since they're aluminum they weight less, and you can run a point higher compression.
Staying with stock iron heads would be cool, but I think you might be happier with a set of aluminum heads. Horsepower = Happiness
You might be able to pick up a great set of aluminum heads that will allow you to flow 600+ HP at the crank for <$1500. You can check out 440source.com for instance.
Old May 28, 2013 | 04:00 PM
383mopar's Avatar
I know aluminium heads would get me better numbers out of the box, but I happen to find a good machine shop that does good work for a decent price. Im looking to get a quote to see how much it would be to get them cnc machined. I don't mind getting the extra work done on the iron heads. I'm familiar with the 440source stealth heads, I was considering them but I decided to stay with the iron heads.
Jvz
Jul 31, 2014 02:38 PM
Dm7x09
28
Mar 20, 2013 04:16 PM
72MidnightBlue
Sep 1, 2008 08:48 PM
ef8340
Jun 28, 2008 07:06 PM
ucfierocharger
Nov 8, 2007 01:54 PM
