Idle timing on 383
Old Jul 10, 2015 | 05:48 PM
70newport's Avatar
Idle timing on 383
Hey guys,
Just curious if you have any suggestions on where to start with timing at idle on my 383. I will be running manifold vacuum on the distributor advance.
383
Edelbrock e street heads
Holley 670 street avenger
Tti headers
Comp cams 268/268 454 454 cam
Thanks for the info!
Gary
Old Jul 10, 2015 | 07:15 PM
Archer's Avatar
70 -
And why are you running manifold vacuum to the distributor?
It's usually set up to use a ported vacuum.
Most of those engines like to start about 10 initial advanced, and tune from there.
Old Jul 10, 2015 | 08:00 PM
Start at 10 with the vacuum disconnected.
Old Jul 11, 2015 | 10:33 AM
DDodger's Avatar
Some people believe in man. vacuum and some don't. I'm in the "dont't" camp, but whatever you do you will HAVE to either run a performance distributor in which you can shorten the advance curve, or else re-curve the factory dist. Hotter cams need more initial timing. 15-20 is not unheard of, and the reason you cannot just "jack that up" is now it will OVER advance at higher RPM unless recurved.
Old Jul 13, 2015 | 11:07 AM
Rooty's Avatar
I run about 14 degrees with mine using a "mild" Lunati cam with the advance hose removed and plugged.
Old Jul 15, 2015 | 02:33 PM
70newport's Avatar
Thanks everyone.
Gotta do some test and tune time. Car pulls awesome once moving but falls flat on its face sometimes even stalls if I hammer it from a stand still
labradorian70
Sep 24, 2014 09:44 AM
joelevelis@comcast.net
Sep 13, 2013 08:46 AM
68newportcustom
Jul 11, 2013 09:14 PM
Gorts 5th
Dec 19, 2012 04:52 PM
a.johansson84
May 27, 2012 03:30 AM
