Installing Rockers
Old Mar 22, 2013 | 03:30 PM
Shrug's Avatar
Installing Rockers
OK I am reassembling my engine. A 1996 Magnum 5.2L
I have torque specs for everything, but nothing says how tight the rockers assemblies should be? Do those get torqued down ro do I just make sure they are tight?
Thank you!
Old Mar 22, 2013 | 04:19 PM
PK1's Avatar
PK1
Use EOIC and tighen the 5/16 bolt to 21 ft lbs.
Old Mar 22, 2013 | 04:27 PM
Shrug's Avatar
EOIC??
Old Mar 22, 2013 | 05:40 PM
PK1's Avatar
PK1
Exhaust Opening Intake Closing.
You need to tighten the rocker bolt when the cam is on its base circle. Meaning no lift is being applied to the valve train. If you do not the spring will interfere with a true reading as the rocker "could" be activated.
Search the forum or net for EOIC. I think it was written up by Coronet500 or 440 Roadrunner in detail once. Same procedure regardless of make. Pretty sure its on here.
Old Mar 22, 2013 | 06:35 PM
EOIC is the simplest thing in the world and works on any engine from a Briggs to a P&W radial
You rotate the engine until...........
The EXHAUST just starts to OPEN and then adjust the intake on that cylinder
rotate until..........
The INTAKE opens and is nearly CLOSED and adjust the exhaust on that cylinder.
Mopar also has a chart, if you have the balancer marked every 90*:
76_roadrunner
Dec 2, 2017 05:22 AM
moparjohnson123456
Jun 14, 2011 01:28 PM
67rockabillydart
Apr 14, 2009 01:11 PM
jane1043
May 8, 2008 07:11 PM
Wonsley69
Feb 22, 2008 04:39 PM
