Intake Manifold For 360?
Old Mar 16, 2017 | 05:35 PM
gearheadmike's Avatar
So i'm cleaning up my 360 and i pulled the 10 ton cast 4bbl intake off and was looking to replace with a lighter aluminum one for the lightness and less emission crap. Well i see small block mopar intakes used are $$$$$ to me there to much even used on ebay.
This is a all stock 360 with q-jet carb. I found a edelbrock torker 340 for $60 and a offenhauser for $125 but both are open plenum and i heard that's not to good for stock/street use. Plus id have to get a q-jet adapter plate for it.
Old Mar 16, 2017 | 06:16 PM
Drag Pak's Avatar
You are just as well off with a stock iron manifold. Ask any Mopar LA Stock Eliminator racer, you will find very little if any performance gain with an aluminum intake.
Grind off the emissions flanges?
You can take the underside heat shield off and remove about 5 lbs of carbon build up as well.
moparjohnson123456
Jun 15, 2011 11:42 AM
M1 Manifold
May 21, 2009 02:23 PM
67rockabillydart
Feb 10, 2009 07:31 PM
Liu Kang
Jan 25, 2009 05:50 PM
68 Sat
Oct 27, 2008 12:31 PM
