Lean burn conversion
I am thinking about converting the lean burn system in my 76 Cordoba 400 4bbl. Any advice on what conversion kit to use would be helpful. Also, can I use the stock carburetor? If not, any advice would be great.
Thanks in advance for your help.
Main thing is to replace the ign module and the dist. You can use stock parts, MSD all in one dist, several choices
http://www.ebay.com/itm/BB-MOPAR-RED...d5e110&vxp=mtr
i have used the chtysler kit that went good. hint: 1 if the cap has a air vent. plug it with JB-weld. 2: get two extra ballast resistors, put them in the glove box. when the first fail to start happens. get one ballast out and replace the one on the fire wall
chuck748
15
Mar 6, 2015 09:30 AM
chykov's76doba
Jan 20, 2014 07:01 AM
rickswanson
18
Apr 9, 2012 08:53 AM
