lifter question
Old Dec 25, 2011 | 08:08 PM
lifted150's Avatar
lifter question
ok so i pulled my valve covers an a few lifters were a little lose motor is a 318, so i thought ok maybe a push rod is bent so i pull the intake, pull the push rods, install a new set an tighten them to factory specs an i can still move a few of the lifters side to side a bit is this normal??? the truck ran great, did not tick, bang ect ect.... also do you got to tighten them when you turn them motor over as well??? i thought i heard i was supposed to but cant remember
Old Dec 25, 2011 | 10:03 PM
Assuming it is a stock LA 318 motor. The rockers are shaft mounted and non adjustable. The shaft bolts should be tightened to 25-30 ft lbs ???? Look it up... Lifters are pumped up with oil preassure to take up the clearance.. Without oil pressure the lifter may be loose It depends on how fast the lifter bleeds down
Old Dec 25, 2011 | 10:37 PM
lifted150's Avatar
Originally Posted by TVLynn
Assuming it is a stock LA 318 motor. The rockers are shaft mounted and non adjustable. The shaft bolts should be tightened to 25-30 ft lbs ???? Look it up... Lifters are pumped up with oil pressure to take up the clearance.. Without oil pressure the lifter may be loose It depends on how fast the lifter bleeds down
ya i tightened them to to the right specs, so i shoucl be good right?? i for got to add that oil is pumped an tightens them up lol, do i re tighten the pushrods after i turn it over or no??
Old Dec 26, 2011 | 11:27 AM
blue 68 gts's Avatar
Theres no valve adjustment, put the rocker shaft on, torque them down and go.
Old Dec 26, 2011 | 06:23 PM
lifted150's Avatar
Thumbs up
ok thanks ya thats what i thought, ya guys did it again
maca
Jun 27, 2014 09:33 PM
RustyBucket
Feb 24, 2014 08:05 PM
will d
Feb 27, 2010 06:29 PM
Erikthegoalie
Feb 9, 2009 03:34 PM
62sportsweep
Apr 7, 2008 03:38 PM
