Need help asap!!!!! Dodge 413 truck
Old Nov 26, 2016 | 11:11 AM
Chryslerguy17's Avatar
I have a 71 dodge motor. It came our of a motor home. The valve covers say it's a 413 rb motor. I took the number off the heads and looked it up. It is a 413. My problem is, there is no block casting number anywhere on the motor. I have searched that thing so much but still no number. The only numbers that are on the motor is 5R (on front of motor) and there is three 6's placed on each side of the block and on the back by the flex plate. The other problem is, I can't find piston's for a 413. They are all either for a 383 or 440. I'm probly us gonna have to bore it an 1/8th inch to a 440. Need some opinions guys. And some history on this block. Thanks
Old Nov 26, 2016 | 11:22 AM
Look on the extended pad pointing forward next to the Distributor... Should be stamped their..
https://www.google.com/search?q=Big+...1FDd5dKYhLM%3A
Old Nov 26, 2016 | 11:37 AM
Your Piston are listed here :
https://www.uempistons.com/catalogs/...te_catalog.pdf
Old Nov 26, 2016 | 12:42 PM
Bob I like the way you jump in and help the new guys out!
Old Nov 26, 2016 | 12:44 PM
Only when I have time.....lol
Old Nov 26, 2016 | 12:49 PM
I'm going to help you one of these days.....
Old Nov 26, 2016 | 02:15 PM
Well I've still got a bathroom and a hallway to finnish Bob, come on over.
The bear and pizza is on me!
Old Nov 26, 2016 | 07:00 PM
Oh...Ok... Sheeeeesh... Let me turn my Skype on, I'm so with you on this...
Old Nov 27, 2016 | 08:19 AM
Ok. I found it. Thank you. It has HT 413. And underneath it, it has 7 14. What does the 7 14 mean?
Old Nov 27, 2016 | 09:00 AM
Glad you found it... The other numbers, I dont remember..
It might be number in line and the casting batch or something like that?
Old Nov 27, 2016 | 11:27 AM
If it's on the pad it could be application, truck as opposed to industrial.??
Just a thought
Craig Kozak
13
Mar 6, 2012 08:04 AM
gearheadmike
Aug 15, 2011 04:22 PM
PLYMOUTH BOB
Jan 13, 2011 11:22 AM
hellzombiex
Apr 20, 2009 11:58 AM
blue 68 gts
Apr 9, 2009 02:06 AM
