Need help identifying engine
Old Jan 16, 2020 | 08:32 AM
rivertafc's Avatar
Can someone help me identify this engine the guy selling says he doesn't know if it's a 318 or a 360 but I suspect it to be a 318.
Old Jan 16, 2020 | 10:54 AM
Chances are 318. What's it in?
Old Jan 16, 2020 | 01:14 PM
rivertafc's Avatar
A 66 Charger, I'm pretty sure it's a LA Small Block but I'm not sure what displacement.
Old Jan 16, 2020 | 01:26 PM
I found this online:
There is a casting number on the side of the block behind the starter that will look something like this XXXXXXXX-318-XX. The displacement is the 3 numbers between the 2 dashes, i.e. 273, 318, 340, 360. Chances are you have a 318 since they were far from gutless, even in the '70s. Hope this helps.
Old Jan 16, 2020 | 01:52 PM
No 360's in '66 but it could be with all the 318 dressings that are on it now. When you go under go in with a can off brake clean, eye protection and a small stiff wire brush to find that number, it's big enough you'll find it easy.
Old Jan 16, 2020 | 01:53 PM
true. the big block was 361... it's a 318 almost for sure if it's the original.
Old Jan 16, 2020 | 02:02 PM
rivertafc's Avatar
Forgot to add that the engine is not original.
Old Jan 16, 2020 | 02:04 PM
oh ok so yeah i'd check the casting numbers.
jakegunter25
Jan 15, 2016 06:42 PM
ARosenbaum
May 6, 2015 08:31 AM
1OldFordMan
Feb 7, 2011 02:58 PM
RROriginals
Jul 24, 2010 06:27 PM
Vaugh22
Feb 8, 2008 02:38 PM
