oil burn
oil burn
have a dodge dart swinger 1971 with rebuilt 318 little over 1500 miles on engine. Problem it takes 1 qt oil every 300 or so miles. seems like i had this problem from day 1. thought after break in would get better. Lack of power also is noticed with engine miss in mid rpm range. never gauged the rpm. Compression test good for all cylinders. 120-123. Did leak down test all about 3-5% on cold engine. Know it should be warm though. Noticed 3 plugs had oil deposits on them rest seemed ok. Once clean up plugs car runs better then plugs foul up again. Thinking maybe oil rings but see no smoke out exhaust when following car. Do have white smoke when first start. Also have knock when 1st start then 3 sec later gone. engine is at full mark with oil, not low. Any ideas would be appreciated.
No would not show on leak down... All the valves are closed......
Im with the guys......
If the heads were done and are in good order.... Attack the intake for not sealing on the valley side.....
Keep us posted.....
Keep us posted.....
Took off valve covers and 6 and 5 rocker were loose. Going to replace lifters. Had a nasty tap after doing the leak down. Hopefully this will fix problem. Will also be checking seals. Thanks for responses.
rickswanson
18
Apr 9, 2012 08:53 AM
dzltd02
Oct 28, 2008 08:25 AM
