Oil Pressure Warning Light Flickers
Old Jan 31, 2016 | 03:56 PM
jstaples2's Avatar
Hi all -
The Oil Pressure light in the instrument cluster started flickering today and I'm wondering what you all thought? The flickering only happens when at idle or when coasting, it does not flicker WOT.
I have an aftermarket oil pressure gauge that reads over 50psi WOT, and in the mid 40's while off throttle. Oil levels are topped off. So, I'm not sure what the issue might be. I did have the oil changed about 200 miles ago however...
Any ideas on where to start or what the culprit might be?
1968 Plymouth Fury 3
Engine: 383
Old Jan 31, 2016 | 06:03 PM
the manual gauge is saying 40psi at idle... I would say the sending unit to the light is bad....
Old Feb 2, 2016 | 05:15 PM
jstaples2's Avatar
That was it. Thanks a ton for your help!
Old Feb 3, 2016 | 10:56 AM
No Problem.... Happy to Help.... Have fun Cruising...
h340
24
Dec 18, 2014 09:19 AM
Skynyrd
Sep 10, 2014 05:24 PM
The Quiet Guy
Dec 29, 2013 09:42 PM
dzltd02
Oct 28, 2008 08:25 AM
