P12 Special delux carburettor problems
Old Aug 14, 2013 | 06:49 PM
BruceB's Avatar
Hi folks. I've posted here before concerning a fuel problem with my P12 stalling and being hard to start. Have been through everything and the car finally seems to run fine, except one problem--when I pull in the driveway and stop, the engine idles down and dies. the only way I can get it to start is to open the throttle all the way and crank the h*ll out of the engine--then it will usually start, with a cloud of black smoke from the exhaust. What can be causing this? Does the car hate my driveway? Any thoughts?
Bruce
Old Aug 14, 2013 | 06:58 PM
Is your driveway sloped? If so, the float is probably too high and the additional angle will over fill the fuel bowl and let gas into the venturi.
What's a P12?
Old Aug 15, 2013 | 02:02 PM
BruceB's Avatar
Thanks. A P12 is a 1941 Plymouth Special Deluxe. Interesting you should ask about my driveway--it does have an upslope, but not a drastic one. You go upslope about a car's length and then it levels out. I just took the car out for a spin and it stalled at the bottom of a hill on a road near here. There is a stop sign at that point and the car stalled there once before. I had a similar problem after turning a corner at the bottom of a hill--only it didn't stall that time, it just stumbled. Tonight when I got home the car ran after I pulled in the drive, but for just about 10-15 seconds, then it died. The car also died once when I parked in a drive that was level So the issue you think is the float. Not being a carb man, is this something easily adjusted?
Bruce
Old Aug 15, 2013 | 02:45 PM
Not being a 1941 carb expert, I'll guess it has a needle and seat that is replaceable. The float can be adjusted by bending the float hinge mechanism. If I was going to open the carb I would have a rebuild kit as the gasket will likely tear then your screwed.
Old Aug 17, 2013 | 05:08 PM
BruceB's Avatar
Well, it looks like the float is the issue--I took the car to a meet tonight and it did its stalling out thing. When I opened the hood gas was leaking from the carb. I tapped it with a jack knife and it stopped. I have ordered a rebuild kit--seems like it wouldn't hurt to redo the carb.
Bruce
Old Aug 18, 2013 | 04:26 AM
Beautiful, keep us posted. A good example of why I tell my boys a man should always have a pocket knife.
Old Aug 25, 2013 | 01:04 PM
BruceB's Avatar
Fixed the float problem and now she runs like a champ! Thanks for your input!
Bruce
Old Aug 25, 2013 | 08:10 PM
68GTX440's Avatar
Always had a soft spot for Plymouths. Bought a rock solid 1948 Plymouth Coupe, back in 67. Drove it a week and dropped the drive shaft while popping the clutch on main street. Sold it for $50. One of those, wished I hadn't moments.
Old Aug 26, 2013 | 01:35 PM
BruceB's Avatar
I have a soft spot for Plymouths too! I remember my dad had a 53 convertible that always seemed to bring rain whenever you put the top down!
faraoneparts
Oct 7, 2019 05:38 PM
xvodysseusvx
Jun 25, 2018 04:38 PM
yesitsme11@yahoo.com
May 12, 2015 03:11 PM
BruceB
Jan 27, 2014 06:59 PM
mrhaney
Mar 8, 2008 12:33 PM
