Replacing the timing chain
Old 04-17-2018, 01:31 AM
willem_at_work's Avatar
Hi there,
I'm planning to replace the timing chain on my '72 225cui slant six. This might be a stupid question, but when installing the new chain, does it need to be oiled or can it be installed dry as it is.
regards. Willem
Old 04-17-2018, 04:49 AM
You could and oil after, I like to soak the chain.
Old 04-17-2018, 05:17 AM
Does it matter which type of oil you use?
Old 04-17-2018, 11:36 AM
any engine oil should be fine I go with the soak it...
Old 04-17-2018, 11:21 PM
Will do. thanks guys!
Old 04-18-2018, 04:50 AM
ZEN357's Avatar
Soak the chain in oil. Never put it on dry.
Gorts 5th
12-19-2012 04:52 PM
dynahd
08-08-2011 03:26 PM
teedeej340
12-01-2010 06:16 PM
roadwarrior86
10-11-2010 11:40 PM
recondotexas
04-03-2010 03:44 PM
Quick Reply: Replacing the timing chain
