Roller rocker tq specs??
Old 03-27-2012 | 08:00 AM
69POLARA383's Avatar
Ok, so Im goin in to replace my blown head gasket and I have the tq specs on the head bolts and valve covers but I have aftermarket steel roller rockers from PRW. They are the fully adjustable kind so I am trying to figure out how to tq em back up after I replace the gasket. This is my first attempt at his so need all the help I can get.
Thanks!
Old 03-27-2012 | 12:20 PM
solid lifters? Hydrolog lifters ?????
Old 03-27-2012 | 01:47 PM
Hydro
Old 03-27-2012 | 03:14 PM
Rocker shaft bolts 25 ft lb.
Old 03-28-2012 | 12:25 PM
Thanks Bremeric but I was trying to get the specs on the adjustable cup/push rod side.
Old 03-28-2012 | 01:42 PM
On the lock nuts I put a wrench on them and then tap it with a rubber mallet. Have to do the same for loosening them.
Old 03-28-2012 | 01:43 PM
If your talking about setting the preload then thats a totally different animal.
Old 03-28-2012 | 02:10 PM
Yes, thats what I'm talking about, sorry I didnt get that terminology right.
Old 03-28-2012 | 03:20 PM
Here you go. The first part talks about where the lifter should be on the cam when your adjusting it. The second part is for mechanical roller lifters and the third part is for your hydraulic roller lifters.
http://www.diamondbackengines.com/te...ng-valve-lash/
Old 03-29-2012 | 09:59 AM
Talking
Thanks, I'll give it a shot this weekend hopefully.
goldenpistol
04-28-2013 05:26 PM
Imfast101
20
03-30-2012 10:32 PM
69POLARA383
09-25-2010 12:29 AM
norcalmopar
08-06-2010 04:51 PM
DUST360
09-20-2009 06:32 PM
