Slant 6 in 1958 D100??? Help
You'll need to swap transmissions, make up some custom motor mounts, transmission mount/cross member, drive shaft, radiator inlet/outlet may be different and wiring (should be pretty simple though).
If you are going to be swapping to a slant 6, swapping in a small block V8 would probably be the same amount of work and you'll gain more power.
That is the easiest and cheapest thing to do with that /6. If the tail house length is short, you could also throw that setup into an A-body car with a /6 and have some fun too.
aepowell
Oct 10, 2013 10:52 PM
