Small block to Big Block Change Over
I have a 74duster with a 318 SB and am concidering going to a 383 or 440 with a 727 Trans........ What troubles will I face with the motor fitting , The Trans and putting Headers on also....... I also have power steering so need to know if the one off the 318 will work also......Someone said that I might have to change the K Member but they wasnt sure...... I could use your Help !!!!!!
Thx in Advance...........
It is doable. Need motor mounts from Shumacher , new radiator, BB 727 trans, drive shaft, maybe the rear end ? all the misc eng brackets. Power steering is the same regardless of engine. Headers - VERY close fit A late 400 would be a better fit
DUSTERforLIFE (09-19-2012)
Have fun! john
