Small block to Big Block Change Over
Old Sep 19, 2012 | 03:04 PM
DUSTERforLIFE's Avatar
I have a 74duster with a 318 SB and am concidering going to a 383 or 440 with a 727 Trans........ What troubles will I face with the motor fitting , The Trans and putting Headers on also....... I also have power steering so need to know if the one off the 318 will work also......Someone said that I might have to change the K Member but they wasnt sure...... I could use your Help !!!!!!
Thx in Advance...........
Old Sep 19, 2012 | 04:47 PM
It is doable. Need motor mounts from Shumacher , new radiator, BB 727 trans, drive shaft, maybe the rear end ? all the misc eng brackets. Power steering is the same regardless of engine. Headers - VERY close fit A late 400 would be a better fit
Old Sep 19, 2012 | 06:23 PM
Thanks, but do u know if the k member has to be replaced as well ????? Thanks for the info
Old Sep 19, 2012 | 09:12 PM
John Van's Avatar
Tvlynn is right on what you need, you can use the same k-member with the Schumacher motor mounts plus their torque strap is a good idea. Check the trunk floor for rust above the spring perches, dusters like to rust there. I have seen the springs come right thru the trunk floor!
Have fun! john
Old Sep 19, 2012 | 09:41 PM
Most of the time you can use it as is. Sometimes it may be necessary to trim the K member and box it in for oil pump / oil pan clearance.
pipdog69
Mar 13, 2012 11:01 PM
74bbroadrunner
Mar 13, 2012 08:19 PM
68satellite
May 23, 2009 05:33 AM
Brent1960
May 17, 2009 04:25 PM
mahd
Apr 2, 2009 09:05 AM
