small block turbo
Old Jul 25, 2014 | 05:43 PM
dredgehammer's Avatar
small block turbo
i am going to be building a new small block this winter and was thinking of doing a twin or single turbo setup, does anyone have any experience with fast 2.0 or boosted setups? just wanted the mopar gurus 2 cents... thanks.
Old Jul 25, 2014 | 09:19 PM
moe7404's Avatar
i know nothing about turbos. but i do know this. the oil drain should dump in to the pan well above the oil level. and it is gravity fed so the hose / tube needs to be big..
Old Jul 25, 2014 | 10:36 PM
I would send you over to the turbo forum
http://www.theturboforums.com/
You need to decide what you expect, what you want. If you just want a simple turbo for a bit of boost, there's several guys that have done that in much the same way. One guy is named "Ward" and there's another both on FABO and at the turbo forum that had done the same thing
http://www.forabodiesonly.com/mopar/...1&d=1255140991
What you do, is use late Dakota / Ram manifolds turned around facing front. You make a crossover pipe going down in front of the engine, and mount the turbo in the pass front corner. The single big exhaust goes up over, and down in the far pass. corner. This is a good way to keep it simple.
Lots of guys have gone TT with these.
If you want a radical "I'd like to dream but can't afford" it deal, Check out "EarlyHemiBill." HE is putting a twin turboed, injected Desoto early hemi in a Valiant. That thing is gonna be a MONSTER
https://www.youtube.com/user/earlyhemibill/videos
Now, I cannot do this man justice. But to "touch around the edges" you are looking at an early Desoto with LOTS of hand made parts. He made a new timing cover, partly so he can use a later more available water pump. He modified the injector setup to use electronic injection. Had made all the plumbing for the turbos and fuel.. I'm sure there's a BUNCH of "little details"
Old Jul 26, 2014 | 08:59 AM
I'm With 440Roadrunner..... The Turbo Forum... or Monte Smith Performance.
http://montesmithperformance.com/
Monte is down in Alabama... Dont get fooled by all the hubb bubb....
Monte likes Mopars also, he can give you all the ingredient's you need.
Also Check with the guys over at the fast mopar forum... There a little easier then the folks over at the Bullet site..
http://www.fastmopar.com/
Old Jul 26, 2014 | 10:32 PM
IF you are thinking about 1,000 hp twin turbo I would suggest an R3/R4 block as your foundation
Old Jul 30, 2014 | 04:26 PM
yes but where does one find a block like that, im sure its slim pickin'
Old Jul 30, 2014 | 05:47 PM
Direct from Mopar or Ebay NOT cheap !!!
http://www.ebay.com/itm/NEW-Fully-Ma...564ccd&vxp=mtr
Old Jul 31, 2014 | 04:30 PM
You could also check with ATI to see what they are doing with their new Challenger
destroked Hemi with a hair dryer
pipdog69
Mar 13, 2012 11:01 PM
74bbroadrunner
Mar 13, 2012 08:19 PM
68satellite
May 23, 2009 05:33 AM
Brent1960
May 17, 2009 04:25 PM
mahd
Apr 2, 2009 09:05 AM
