smoke problem passenger side
Old Apr 6, 2015 | 07:10 AM
dart75's Avatar
I recently have had quite a bit of whiteish gray smoke coming from the passenger side exhaust.. I've heard it could be a warped head... or head gasket.. or possible oil rings... any suggestions?
Old Apr 6, 2015 | 09:02 AM
DDodger's Avatar
First thing to do is look at the plugs, and try and determine if it's oil or coolant
Next would be compression check and leakdown test Does it lose coolant?
Might be a valve seal(s)
Old Apr 6, 2015 | 03:04 PM
do you run anti freeze ? Smell the exhaust, if it is sweet the head gasket is leaking. otherwise It could be stuck rings if it has been setting for years.. Maybe oil guide seals
Old Apr 9, 2015 | 12:36 PM
Rooty's Avatar
If it's blueish it's oil, if it's whiteish grey it's coolant, if it's black it's rich and if it damn near kills you when you breathe it, it's probably OK. Keep your face away from those pipes or you'll look like a mime, a chimney sweep or something that fell off the autopsy table. You've been warned!
Old Apr 10, 2015 | 07:08 AM
dart75's Avatar
so all the plugs were burning good except for Cylinder # 2 on the passenger side.. it looked black and wet..
Old Apr 10, 2015 | 10:05 AM
moe7404's Avatar
the 1966 and older 318s. had a very small oil drain back holes from the head. . when the hole plugs up they will smoke bad. they can be pushed clear.
Old Apr 10, 2015 | 05:39 PM
Might have a bad spark plug.... Plug wire..... Or need a set of Valve stem seals.. Check the compression and see if it's good?...
Old Apr 11, 2015 | 04:48 AM
xaza's Avatar
Based on the title I was thinking open the passenger door and push them out.
Old Apr 11, 2015 | 06:01 AM
wildsiderides
Jun 1, 2019 09:23 PM
Matthew Winters
Oct 23, 2014 01:59 PM
chykov's76doba
May 16, 2013 10:46 AM
ahrkar
Jun 11, 2012 09:28 PM
BuckNeccid
Oct 30, 2008 12:42 PM
