Is there a new and improved header gasket?
Old Sep 19, 2014 | 09:26 PM
mslisaj's Avatar
Well I have old headers on my two 440's and I have always had little leaks between the siamese ports in the center of the heads. The old fix was take two Mr. Gasket header flange gaskets and put Number One Permatex between them and that would be your best bet to solve the problem. Well with the advancement of products that we're all seeing and enjoying today has some one made a thick or thicker header gasket for this kind of problems?
Just thought i would throw this question out there being I am sorting out ALL the little problems with my show cars.
Thanks for any suggestions or help with this.
Lisa
Old Sep 20, 2014 | 09:10 AM
I have had luck with the Mr Gasket Ultra seals....
But I have also had to have headers removed to have them Belt sanded flat again. You know the ones that are bowed way to much and just wont seal.
Old Sep 21, 2014 | 04:53 AM
Gorts 5th's Avatar
Smile
I make my own using foil backed a/c tape and thick gasget material ..the spend the next few months cheching and retightning untill the gaskets are compressed enough
Old Sep 21, 2014 | 07:34 AM
mslisaj's Avatar
It seems we've all come up with different tricks to get the job done. The general problem with headers is they are a PIA to get in. Plus they get damaged by forcing them into position and I have to admit I am guilty of that. But if the Mr. Gasket ultra's are the "new" ticket I'll have to check them out. I truly don't want to remove these headers from the vehicle. But I can slip them off the studs and change gaskets I'll look into them and come up with something.
As usual I appreciate you guys taking your time to respond with your idea's.
Lisa
Moparod
Jul 28, 2014 07:23 PM
EdR
Sep 1, 2013 06:51 PM
2thpic
Apr 6, 2012 12:20 AM
ef8340
Aug 8, 2008 02:47 PM
