Timing Question?
Old Sep 22, 2014 | 06:37 PM
Robert Weaver's Avatar
Question Timing Question?
Hello,
I rotated the engine today and forgot to put the Dizzy back before doin so, can I still get it back in time later? Would a Timing Light help?
I believe my Haynes Manual says set 5 degrees BTDC
Old Sep 22, 2014 | 06:58 PM
labradorian70's Avatar
Originally Posted by Robert Weaver
Hello,
Im sure someone is going to ask you what engine/car you are asking about?
cheers
Old Sep 22, 2014 | 07:28 PM
Oh yeah forgot, it's a 74 Charger SE 5.9 360 2bbl
Old Sep 22, 2014 | 07:32 PM
Sure you can... Stick your finger in the #1 hole turn the motor till you feel it come up on compression and set it on TDC and drop it in.... Should be good to go !!!
Old Sep 22, 2014 | 07:37 PM
Is Compression when air blows ur finger out and would using the trigger make it easier when doing that method? Does the Vac Adv on the dizzy usually point to the pass side or drivers side?
Old Sep 22, 2014 | 07:38 PM
Yes.....
Here you go.... I Know it's brand X... But the same apply s...
Old Sep 22, 2014 | 07:45 PM
Thank for the vid.
Old Sep 22, 2014 | 07:46 PM
Old Sep 23, 2014 | 02:35 AM
Drivers side as I recall. Oil sender is on opposite side I would set timing to 10-12 deg
Old Sep 23, 2014 | 05:25 AM
Vacuum canister points to the passenger's side (right side). The oil pump drive slot should be along a line pointed at the first intake manifold bolt on left side. With all in place make sure you adjust rotor slightly to be before #1 plug wire terminal for advanced timing for quick fire up and have timing light ready.
To adjust oil pump slot use a large slot screwdriver to rotate it and it should walk up with a bit of a wiggle.
Old Sep 24, 2014 | 07:16 AM
Also, when u go to set the timing, does both the dizzy & carb need to be plugged? & is the valve train IEIEIEIE or IEEIIEEI?
Old Sep 24, 2014 | 08:49 AM
Only side needs plugged is manifold, and on engines with "ported" vacuum, you really don't even need that.
Why you need to know valve sequence?
All you have to do is look
Outer two are exhaust, center two are exhaust so E - I I - E E - I I - E
Old Sep 24, 2014 | 09:47 AM
Just curious cuz i figured it would help with finding TDC on compression stroke. Haven't had to do it since workin on a chevy 350.
Old Oct 2, 2014 | 10:01 AM
Dumb question, does all but the #1 spark plug need to be in before finding TDC?
Old Oct 2, 2014 | 02:38 PM
Not dumb. It's easier finding TDC with them all out as the engine will turn over much easier.
Find it put them all in then do your wires. I usually put a pen mark cylinder number on the boot.
Old Oct 2, 2014 | 05:27 PM
pro-tech's Avatar
I know this question will be coming so hear is the answer... #1 is the front plug on the left bank (drivers side) and the firing order is 1 8 4 3 6 5 7 2... clockwise on the dizzy... Hope this helps you....Also when you are on TDC the dist. rotor should point dead straight ahead if it doesn't, the oil pump drive is out of index...And needs to be adjusted by turning it counter clockwise with a flat screw driver/oil pump priming tool until it does point straight ahead. (The gear will come out of the cam and allow you to move it to the proper index then just turn it clockwise to lock it back in to the cam to be done right)...Bill
Old Oct 2, 2014 | 05:41 PM
Oh, I thought when your at TDC the Rotor was suppose to be pointing at #1 plug?
Old Oct 2, 2014 | 07:17 PM
#10 and what Bill said. Straight ahead and match #1 plug wire to it. Dan.
Old Oct 13, 2014 | 12:58 PM
Does it matter where the rotor is pointing as long as its at #1 pkug wire and at tdc comp?
Old Oct 13, 2014 | 01:35 PM
No. As long as you have room for the vacuum canister to move when timing it.
Old Oct 13, 2014 | 01:50 PM
Cool beans. Thanks guys.
19newport72
Mar 27, 2024 06:44 PM
Gorts 5th
Dec 19, 2012 04:52 PM
a.johansson84
May 27, 2012 03:30 AM
pipdog69
Jan 22, 2009 03:20 PM
62sportsweep
Apr 5, 2008 07:03 PM
