Tuning a 360
Old Feb 4, 2014 | 12:18 PM
Darren grosvenor's Avatar
Tuning a 360
Hi there lady's & gents I have a 36 mopar & want to tune & over haul it I'm having the bottom end rebuilt I need to no wot cam I shoul use. Also as I'm now not going to supercharg or turbo it should I put higher comp pistons in it. Was going to spend money on porting & bigger valves & rockers should I buy after market heads . Thanks darren
Old Feb 4, 2014 | 05:47 PM
I'll give it a whirl. Comp Cams.
Stock converter XE268H
2200+ converter XE274H
Old Feb 5, 2014 | 02:07 PM
Thanks For the reply not sure wot that means as I no nothing about mopar. Understand the comp cam lol. Thanks darren
Old Feb 5, 2014 | 03:29 PM
If you look up those numbers they will come up with the cam profile numbers and recommendations. One says it will work with a stock torque converter if your planning on running an automatic transmission, the other wants a higher stall T.C. so it won't stall or stumble at launch. What you plan to do with the car is all important, here are some order forms and you can see that every detail is asked for to get the power in the optimum RPM range for the application.
http://www.crower.com/media/pdf/cam_form.pdf
http://www.iskycams.com/pdfcatalog/2004-05/page216.pdf
Old Feb 6, 2014 | 12:38 PM
Ok now I'm with you. I will look at wot you've sent me & see wot I can doo. I want to run a Manual box.
mjcolemo
Apr 29, 2013 07:34 PM
mjcolemo
May 28, 2012 03:09 PM
Cordoba77
Jan 7, 2011 10:15 PM
Barfly
Jun 2, 2010 07:44 PM
scotts74birds
Sep 24, 2009 02:14 PM
