tunnel ram setup
Old Jun 8, 2013 | 06:55 PM
383mopar's Avatar
tunnel ram setup
im going to be building a mild 383 stroker. i was thinking about stroking to 431 or 450cid. im getting a free tunnel ram, and i was curious about what cfm carbs to use. i dont really have much experience with tunnel rams, so any advice on 383 stroker kits and tunnel ram setups would be great.
Old Jun 8, 2013 | 07:21 PM
inri's Avatar
The tunnel ram is too much for a mild 383 stroker. More torque and HP on the bottom end with a single plane in my opinion.
Old Jun 8, 2013 | 07:35 PM
Archer's Avatar
383 -
Tunnel rams has two purposes. High end (high rpm) performance and a visual "wow factor". Street drive-ability, not so much.
So it kinda depends on what you're doing with the car.
Old Jun 10, 2013 | 07:00 AM
PURPLE HORONET's Avatar
I like tunnel rams, going to run one on my project. But I am going for the wow factor. You are better off with a single if you want all out performance. The free tunnel ram is the least of the cost.. I would run to holley 450's with mechanical secondaries with out the rear pumps. They are made for a tunnel ram. Any vacuum secondary carb is useless on a t-ram
450 carb
http://www.summitracing.com/parts/hly-0-9776/overview/
Old Jun 10, 2013 | 10:49 AM
NOT true.
I suppose it depends on the engine and cam, but I ran a pair of 600 vac sec Holleys years ago, and they worked just fine. I've seen (and so have you) AFBs on a TR. This was a 440, mechanical cam, 10.5:1, approx .5 lift x 300 duration. The damn thing just hauled. It was a bit numb right off idle with either the TR orthe then new Torker and an 800 DP.
Old Jun 10, 2013 | 03:49 PM
Originally Posted by 440roadrunner
NOT true.
The old carters are the only vacuum carbs I have ever seen work ok on a t-ram. Never had any luck with a holley vacuum carb. Power brakes barley work with a big cam how can it ever pull two vacuum carbs open on a T-ram.
Ps got a pair of holley 600 vacuums and a 3 eyed monster scoop I will let go cheap in interested.
t/s1148
Apr 29, 2015 11:09 AM
H-Pattern
Mar 2, 2011 02:58 PM
cliffg50
Dec 17, 2009 02:37 PM
Team Gridlock
Aug 20, 2009 05:19 PM
ratkiller
Feb 5, 2009 03:30 AM
