Vacuum pump
Old Aug 4, 2013 | 09:03 AM
1968newport's Avatar
Vacuum pump
Any suggestions? Prefer electric. I need a vacuum pump to run my brake booster. Do I need to tie it into my valve covers to give the motor some vacuum as well?
I'm confused.
I'm running a 6-71 blower on my stroked 383.
Old Aug 4, 2013 | 09:50 AM
IF it was mine I would convert to manual brakes !!!!
Old Aug 4, 2013 | 12:23 PM
I agree....
Old Aug 4, 2013 | 08:05 PM
Really? What is the difference? What do manual brakes feel like?
Old Aug 4, 2013 | 08:06 PM
....and what is involved inthe conversion?
Old Aug 4, 2013 | 11:13 PM
moe7404's Avatar
dont you have vacuum between the carbs and blower?
Old Aug 5, 2013 | 03:43 AM
You need to remove the booster, Then install the reinforcement plate that goes on the engine side for manual brakes. Then you need a longer rod for the manual master to the peddle It's an easy swap just awkward working under the dash
Old Aug 5, 2013 | 06:21 AM
There is Hydratech that makes a brake assist unit that uses power steering fluid pressure. There are some who use a newer Mustang vac unit.
If you search for pumps there are tons of them out there, electric and belt driven.
Old Aug 5, 2013 | 07:03 AM
SSBC makes a nice electric one.
Old Aug 5, 2013 | 07:54 AM
The term is hydroboost, and has been used on Chev trucks since the 70's That is certainly an option.
Old Aug 5, 2013 | 08:03 AM
Thanks for replies. I have been researching plenty, and every blower motor I have read about states that this is an issue. So it got me thinking. I would think that there would be sufficient vacuum between carbs and blower, but its contrary to what I was reading so I wanted to ask.
Old Aug 5, 2013 | 12:35 PM
moe7404's Avatar
just my idea. if there is some vacuum between the blower and carbs , a air tank and a check valve between the two to hold the vacuum in the tank, might work. that way when the carbs open the vacuum under the carbs goes a way, but the tank holds vacuum cause the check valve stops the vacuum from going out through the blower top.
Old Aug 5, 2013 | 01:27 PM
Because of the cam, I don't think I will have enough vacuum.
Old Aug 5, 2013 | 04:03 PM
To 440, it's not a "term" it is the name of the company.
Old Aug 5, 2013 | 04:29 PM
moe7404's Avatar
i dont know much about blowers. you most likely know more than i about how much vacuum the blower will have. did you know that blowers was first made to move smoke out of black smiths shops?
Old Aug 6, 2013 | 08:40 AM
It's just best to have manual brakes and not take a chance. Not say you cant have power brakes because you can, It's just a lot of work. I think.
As for the blower / engine... Make sure when you build your motor to use all the MFG specs for bore clearance's and ring gaps for those type of pistons.
As for your crankcase ventilation... (For Me) I think the header Vac kit works best. and it's simple.
Just my 2 cents
Old Aug 9, 2013 | 03:02 PM
Can I or just use a breather filter on my valve covers? What do you mean crankcase ventilation?
Old Aug 9, 2013 | 03:03 PM
Manual brakes it is. Now where do I get a conversion kit for it?!
Old Aug 9, 2013 | 04:07 PM
http://www.jegs.com/i/Milodon/697/85...FYl_Qgod70MAyA
This is what it look like hooked up...
http://www.carcraft.com/techarticles...uum_pump_test/
Sorry,,, i could only find a chevy on the stand really quick.Too show you...lol
Old Aug 9, 2013 | 04:11 PM
Not the only guys in town....But...
http://ssbrakes.com/
66coronetgirlie
Aug 9, 2010 10:41 PM
340CUDA
Mar 16, 2009 05:27 PM
Commando
Sep 23, 2008 07:35 AM
gotdust
Aug 10, 2008 12:14 PM
burnsy26
Oct 1, 2007 01:35 PM
