Valve cover torque '66 Satellite
Old Apr 14, 2013 | 07:41 PM
cork1958's Avatar
Anyone know what the correct ft. lbs. torque to put on bolts for valve covers on a 1966, 361ci, Plymouth Satellite is?
Thank you
Old Apr 14, 2013 | 09:50 PM
40 inch lbs
Old Apr 15, 2013 | 01:54 AM
cork1958's Avatar
Thank you
According to this website, http://www.convertunits.com/from/inch+lbs/to/foot+lbs that equals all of 3.3333333320000005 ft. lbs.
Old Apr 15, 2013 | 08:51 AM
You can download a free 66 shop manual over at MyMopar
http://www.mymopar.com/downloads/ser...ice_Manual.zip
However the page numbers displayed on the pages are the Mopar "dash" numbering system, but the no's in your viewer are consecutive, so you have to "play" with page no's. See page 394
Torque specs are in the back of the engine section. Pay attention to inch lbs vs ft lbs. Biggest problem with leaking VC and oil pans are OVER tightening.
Attached Thumbnails Valve cover torque '66 Satellite-torque1.jpg   Valve cover torque '66 Satellite-torque2.jpg
Old Apr 16, 2013 | 12:45 AM
cork1958's Avatar
Hey,
Right on!!
Thanks for that link to the shop manual roadrunner.
Old Apr 16, 2013 | 02:00 AM
Also ! MAKE sure you have the special washers
Old Apr 16, 2013 | 03:03 AM
jacilynn_s's Avatar
A few things when it comes to cork gaskets vs the original ones.
The original ones were compressed paper gaskets and you could torgue these down. Havent seen those for years though.
Now we have either neoprene that like to **** out or cork.
With cork you tighten down by hand till tight then go about a 1/4 -1/2 turn more. If you go by the specs you will split the gasket and it will leak.
Neoprene if you tighten too much they stretch out and get the same thing. If you have stock valve covers they have a ridge indent that helps to keep gaskets in place. Aftermarket don't.
Use silicone sparringly on the gasket enough to help it stick but not enough to puke out. Oil and gas eat silicone so its a bad idea to go with silicone alone.
Use a small amount on the threads of the valve cover bolts. It helps to keep the bolts from coming out and seals them at the same time.
Old Apr 19, 2013 | 01:57 AM
cork1958's Avatar
Thanks for the replies folks. Have the car all back together after having done a head job with hardened valve seats, new stainless steel lifters and new springs, and installing a new cam and timing chain and fuel pump among a few other little odds and ends.
Did have a small drip on each of the 2 bottom bolts of the valve covers after a few miles of driving, but snugging them down a hair more has cleared it up.
Now, to get the oil pan gasket changed after I get my 500 mile break in on the cam and I should be drip free!!
Thanks again
lifted150
Jul 8, 2012 10:27 PM
mopar777
May 19, 2011 06:24 AM
hippo204
Jun 10, 2010 07:40 PM
sgnrulz
Jan 13, 2010 09:03 AM
Coredoba
Jul 25, 2009 12:29 PM
