Water from exhaust manifold bolt
Old May 14, 2025 | 09:29 AM
Kuvasz101's Avatar
I don't understand a few things. One is how planes fly, and the other is why Chrysler would have an exhaust manifold stud enter a
water jacket in the head. I know this is normal and have come across it many times. I just repaired a leak that could have looked like a head gasket but wasn't.
Old May 14, 2025 | 11:56 AM
It what it is!!!! Lol
the Mopar would!!!
Old May 14, 2025 | 08:49 PM
dodgem880's Avatar
Why are the studs also undersized? Their 5/16 instead of 3/8...
Old May 15, 2025 | 05:35 AM
Kuvasz101's Avatar
I don't ever recall removing broken studs on Mopar V8s. I certainly recall plenty of leaking studs. That job doesn't look like a fun one, but it looks like you're on the home stretch. Studs are meant to be moderately tightened gaining its fastening strength by using all the threads compared to a bolt that gains its strength mostly where the tip tightens into the hole. I'm sure Chrysler had a thought-out plan but I'm still searching for it.
Old May 16, 2025 | 12:22 AM
Removing broken studs on any installed V8 is a pain, GM and Ford have problems with manifold bolts breaking and if you think your Mopar is bad try doing the same job on a newer GM pickup. Aluminum head junk hardware and no room to work on it. You finally get the bolt loose and the electrolysis on the end of the bolt reams the threads out in the head.
Fun day
Old May 16, 2025 | 05:14 AM
Kuvasz101's Avatar
A friend of mine who was an engineer said "it makes sense to have coolant touch the studs. He said by doing that it reduces the amount of expansion and contraction that may crack the manifold. Did Chrysler really think that much back in the day?
My72D100
Oct 4, 2018 06:57 PM
aarcuda7954
Sep 7, 2014 06:58 PM
moparfreak66
Jun 30, 2013 08:41 PM
Ckurish1367
Aug 28, 2012 09:02 AM
auerdoan
Jan 16, 2012 12:01 PM
