Leaky manifold bolt
Old Aug 28, 2012 | 08:08 AM
Ckurish1367's Avatar
Leaky manifold bolt
I have a 400 that is leaking anti freeze out of the back bolt on the right side. Are there any quick fixes for this?
Old Aug 28, 2012 | 09:02 AM
Gorts 5th's Avatar
Smile
is the bolt lose over time they will loosen up
if you have too remove the bolt [after draining the coolant system] and clean it add a sealant to the threads re-install and tork to specifications "quick fix" if it is the bolt it could be the back of the manifold gasket is leaking at the water jacket
or you could remove the manifold and re-install new gasket set check the remaining water jacket ed bolts for rust and wear
DartSwinger
Jul 31, 2012 10:02 PM
patsquatch
Jul 26, 2012 02:29 AM
Mr. Belvedere II
Jun 21, 2012 08:50 AM
Red Devil
20
Apr 18, 2011 06:05 PM
mahd
Sep 13, 2008 04:30 AM
