What Is this hole for?
Old Jan 21, 2024 | 03:32 PM
Luis Morales's Avatar
Hi guys. I would like to know what Is the function of this hole located in the head of the last rear cylinder? Thank you.
Old Jan 22, 2024 | 04:26 PM
When the head is mounted to the engine block. If i recall, you use that plugged hole to insert a rod down in to find "TDC" Top Dead Center of the piston...
Don't know why they used the number 6 cylinder instead of the number one cylinder? But guess it doesn't matter... result should turn out the same...
Old Jan 22, 2024 | 04:30 PM
Thank you very much!
Tenn86
Aug 24, 2023 07:06 AM
Andy777
Mar 25, 2022 06:54 AM
dodgem880
Oct 12, 2019 10:41 AM
Crazy4Carz.Com
Aug 17, 2009 07:55 PM
kszysio
Mar 6, 2008 05:39 PM
