Will it mess any thing up ?
Old Feb 24, 2014 | 07:52 PM
Mike Laudenslager's Avatar
Ok I have a 1998 dodge ram 1500 318 ' my question is is there any way possible to remove my catolatic converter off of my truck without messing up my emisinins and not turn on my check engine light comeing on or not messing any thing up let me know if u have any solutions?
Old Feb 24, 2014 | 08:53 PM
Federal law says it has to be there unless it is off road vehicle
Old Feb 24, 2014 | 09:05 PM
Ex HACK tly. The thing is, there is (at present) no real inforcement towards individuals of automotive smog laws. If your state has any form of inspection, "this depends." In some states you must pass an underhood physical test as well as a tail pipe test. This also might be up to the inattention, the laxness, or outright bribery on the part of the inspector.
I would certainly check state law before removing.
Old Feb 24, 2014 | 09:33 PM
OK but will it fickle any thing up on my truck I couldent give a **** about the cops I'm just worried about my truck being hurt after I do it I just need to know if it will or if it won't is there any I can keep it from the check engine lite coming on?
Old Feb 25, 2014 | 02:39 AM
Myraman's Avatar
It may mess with some sensors. I know I had a 318 in one of my cars without the cc, but I didn't have the sensors / computers that are on board today. I am really not sure though. What I am sure of is if you hack it off, unless you know someone real close that is willing to inspect your vehicle without the cc, it won't pass inspection. Definitely check laws in your state and your homework on inspections before hacking off. The coppers will never check unless you really give them a reason too.
I'll do some more checking to see what I can find. I will be talking to a couple of friends today that will have some insight. I'm sure someone here has and will have some more info too. Good luck.
Old Feb 25, 2014 | 07:38 AM
The answer in no.....
You can not remove the cat's without messing up your emissions...
Old Feb 25, 2014 | 08:44 AM
speedog24's Avatar
From my knowledge and experience, the O2 sensor after the catalytic converter is the only sensor that will be affected. The sensor after the cat only serves the purpose of letting you know that the cat is going bad, meaning it has no control over how the vehicle runs. So no, removing the cat won't affect any of your main sensors. BUT, it will trip the check engine light because it knows the cat is bad/missing. So while it won't hurt the way your truck runs, the light WILL be on. You have to find a way to trick the sensor into thinking the cat is still there for the light to go off. Performance wise, removing the cat won't give you nearly the gains everyone claims. Unless your motor is some high-performance monster, a cat doesn't hurt it any. Your best bet if your cat is going bad is to replace it with something like Magnaflow's universal high-flow cat. It will keep your truck legal, your light off, and has better flow characteristics than most factory cats.....just my 2 cents
Old Feb 25, 2014 | 10:27 AM
OK thank you Gus for your input now my next question is is there any thing such as like a after market catalog just for mopar parts?. If so where and how do I get it IV looked at summit raceing and jegs catalogs and 90%my of the parts are for Chevy or ford?
Thanks mike
Old Feb 25, 2014 | 02:31 PM
pro-tech's Avatar
Is this a double post on the same thing??? The answer will always be the same...Bill
moe7404
Nov 20, 2013 05:25 PM
Zach8200
Apr 25, 2012 09:39 PM
lgad
Dec 8, 2011 10:19 AM
RROriginals
Jun 21, 2010 09:50 AM
64fury
Dec 31, 2009 01:24 PM
