01 / 42 trans
Old Dec 3, 2014 | 11:20 AM
moe7404's Avatar
01 / 42 trans
have a 01 dak V6 42 trans stock w / 4.1 rear.. can i have control over ingaugeing O.D. manually early? if i can turn off in time. LOL LOL correction. edit change. i mean ingauge the converter lock up. not O.D.
Old Jan 1, 2015 | 01:20 PM
Gorts 5th's Avatar
Smile
Its possible by installing switches and relays
"MY BIG TIME SWAP" post has some info may help you
in town I use lock up alot ..up too 45/50 mph
Old Jan 1, 2015 | 04:34 PM
moe7404's Avatar
yep checked it out. lots of great info. the one diagram with two solenoids might work on my 42 trans. but i want converter lockup only. i was thinking of using the seat belt on sw. and a vac sw to turn it off with heavy throttle opening. that way you dont have hi horsepower at low sreed. iam thinking i dont want hi horsepower at low speed and converter lock at the same time. I.E. lockup only at light throttle.
Old Jan 4, 2015 | 01:26 PM
Gorts 5th's Avatar
Smile
PACT.com has a kit to.automaticly shift od and Lu check it out it may be a better choice for your needs
lemontwist73
Apr 24, 2008 04:47 PM
ppkaprince98
Feb 5, 2008 12:07 AM
lotus79
Jan 21, 2008 10:44 AM
rubadub
Nov 19, 2007 11:02 PM
skimo0104
Dec 30, 2006 09:50 PM
