1963 Dodge Dart No Drive
Old 10-04-2018, 02:40 PM
Donovan's Avatar
First let me thank all of you who reply to this.
Second this is a long post please read carefully.
I have two questions.
Known information about the car.
1. 1963 Dodge Dart 270 four door.
2. Slant six.
3. Push button automatic transmission.
Details of problem.
1. Started car as normal.
2. With foot on the brakes. Released the parking brake. Released the parking pawl.
3. Tried to push in drive button to no avail.
4. Pushed in reverse button I have reverse.
5. Pushed in 2nd button I have 2nd.
6. Pushed in 1st button I have 1st.
Questions
1. Is the problem just the inside push button mechanism? Or possibly the cables.
2. What is the easiest way to remove the push button mechanism?
I have a 2nd 1963 Dodge Dart with a push button automatic so no worries there.
Thanks again,
Donovan Frasure
Old 10-04-2018, 03:14 PM
Have you confirmed that pushing the drive button does or doesn't shift the transmission as in move the lever on the transmission to drive?
Old 10-04-2018, 03:20 PM
Donovan's Avatar
Yes that's correct I Tried to push the button in and couldn't push it in at all.
Old 10-04-2018, 04:49 PM
xaza's Avatar
I believe what Iowan was asking is, Have you shifted transmission into drive at the tranny? May have to disconnect cable to move tranny linkage by itself. Not familiar those myself.
Old 10-04-2018, 06:18 PM
Donovan's Avatar
Sorry Lowan I miss understud the question.
No I've not disconnected the cable. I was under the impression that because the transmission goes in 1st and 2nd that the transmission will go into drive but the Drive button will not push in.
Old 10-05-2018, 02:03 PM
Donovan's Avatar
Solved
I thank everyone for the help. I removed the the push button mechanism cleaned and lubricated all moving parts. Put it back together and it works fine now. NOTE: when taking the mechanism off the very small clips that hold the cables on place them in a cup or tray so you don't lose them.
Old 10-05-2018, 03:07 PM
Thanks for postings the solution to the problem.
Old 10-05-2018, 03:11 PM
Donovan's Avatar
If it helps someone else then I'm glad to help.
ralphy
10-31-2021 12:51 PM
Ben Pfeffer
05-17-2017 05:58 PM
ottoscustoms
08-10-2013 02:17 PM
polyspherical
06-01-2012 08:36 AM
63DDart
04-27-2011 05:32 PM
Quick Reply: 1963 Dodge Dart No Drive
