3.23 gears for 489 8 3/4 Rear.
Hi, guys. New to the forum here. I've been shopping for a new cam for my 383 and it seems my best options out there aren't too compatible with my stock 2.76 rear gears (was a 2 bbl). I'm trying to find a set of new 3.23 ring and pinion gears but I've had no luck in locating anything for the 8 3/4 489 casing. The closest I can find are 3.55. Also any recommendations for brands? Richmond, Titan?
Thanks.
Thanks.
3.55 is a fun gear set and like Archer said, that difference can be made up with tire size.
Richmond, Yukon, Motive are the only gears that I will install.
Stay away from USA Standard as they are noisy (says so in most of their discriptions), G2, Nitro, any of the cheap brands. There is a reason they are cheap.
Maybe but my engine has had only the heads redone. The Short block is stock. The calculator does factor the tire diameter. My 2.76 gears for comparison give you about 2000 rpm
I routinely like to drive it at highway speeds and make it out to Moparfest both days ( a 2 hour plus round trip). I don't think I'd be too happy having to ***** foot it on the highway when I can't keep it below 70 mph right now. I think the 3.23 gear would be the best all around choice but all I can find right now are used. I find it hard to believe that nobody builds a new one. If it comes down to it I probably will just go with the 3.55 but I would take the 3.23 if I could find them.
This is what I was able to find when googling 8.75 489 3.23 gears. Type that into Google and click on the shopping tab and you'll see some on ebay too.
http://www.4x4groupbuy.com/store/sup...g-p-61237.html
I looked into that too. I guy I work with who races his Dart, and knows a lot more when it comes to working on cars, told me that it's a quick changeover. The problem is I'm trying to keep costs down, and was hoping to just locate a 3.23 and be able to improve performance, be compatible with the new cam, and still be able to cruise comfortably on the highway.
Dropping another 800 or so bucks (over a set of gears) is out of the question. Hopefully I can locate some good quality used ones. Those new ones from the off roader website are pretty pricey. $400? Most of the ones I've looked at are around 200. Must be meant for racing and rock crawling.
hmiller79
Jul 25, 2010 03:36 PM
johnhuckin
Mar 28, 2009 06:27 AM
