413 trans
Old Oct 14, 2012 | 03:15 PM
talulah's Avatar
413 trans
I have a 413 with the longram manifolds that I will be installing in a 31 Plympout coupe and want to use the 833 4 speed trans. What will I need to do to make this happen
Thanks,
Bill
Old Oct 14, 2012 | 04:37 PM
blue 68 gts's Avatar
You'll need a bell housing to fit the 833 and 413. The trans will bolt to the bell housing. Get all the correct Z bar linkage and whatnot. Custom drive line. Probably have to hack the floor up to get a shifter to work.
Ect.
Old Nov 10, 2012 | 03:54 PM
moe7404's Avatar
dont for get a input shaft bushing in the end if the crank. it is a remote posabity a 413 may not have the hole for a bushing.
Old Nov 10, 2012 | 07:20 PM
Yes check the pilot bearing hole out CAREFULLY. Chrysler was not only bad at leaving these undersized for auto cars, but not DEEP enough. A common fix was to chop about 3/8" off the transmission shaft. be sure to measure that depth carefully and make sure you have clearance.
I don't remember for sure, but it seems to me early engines had a different crank flange, and some heavy truck/ industrial 413's certainly do.
Old Nov 11, 2012 | 07:53 AM
Gorts 5th's Avatar
Question
i would hate to chop the input shaft one mistake and your finished, and what if later you still got the trany and now a new motor with the proper pilot hole in the crank?
Old Nov 11, 2012 | 10:25 AM
This, "back in the day" used to be a fairly common fix. It does not hurt the transmission. If you have ever seen the shaft on an A-833, it has a very large and long chamfer. Basically, you cut this off, so you are not losing much if any of the actual shaft length. These have a very long pilot, and plenty of room.
"One mistake?" I'm not suggesting you use an axe, cutting torch, or stoneage tools to perform this operation. On the other hand, careful thought with a hacksaw will result in an acceptable cut
Your alternative is to find another crank, or pull the crank which is in the engine and have it machined.
Old Nov 11, 2012 | 12:08 PM
MrOldart2U's Avatar
Ect.
Going into a 30's model anything and fab is GOING to come into play, z-bar linkage wont be 'out there', in this situation Hydro is the way to go, as nothing from 'stock' will not work without modifications....
Old Nov 11, 2012 | 12:11 PM
Chryco Psycho's Avatar
This rings a bell , I think they may have had a different crank flange depth . I never trim the front off the input shaft you can deepen the hole easily & use the Dakota roller pilot brg in the torque converter recess instead .
I agree with using a hyd clutch , Tilton & McLeod both have hyd release brgs available , I like the McLeod design better having used both .
elmo7268
Nov 4, 2010 08:26 PM
griz2575
Jun 24, 2008 06:13 PM
poolinstaller
Oct 27, 2007 07:34 AM
poolinstaller
Sep 13, 2007 05:23 AM
Cardude
May 2, 2007 03:57 PM
