440 Automatic Trans Stall Convertor Help
Old Feb 10, 2012 | 05:10 PM
Potterymaker1's Avatar
to figure out what type of car my 440 came out of. Currently in a 1969 Dodge Charger RT. I strongly believe motor is original but not certain. Marked on Block Vin Pad E 440 12 16HP2
Also trying to figure out if I need a weighted stall convertor or a non weighted convertor for that motor. 727 Transmission not original.
I would appreciate all help. Thanks Ben
Old Feb 10, 2012 | 07:02 PM
Garys69RR's Avatar
Im pretty sure the E means it was built in 1969. The HP means high performance. Not sure on the 12 or 16 or 2. If the front harmonic balancer is about an inch wide, then it would be a forged crankshaft. Hence internally balanced and no external balancing used. This is the case on most 69-440 engines. The 440 6 pack was the exception and was externally balanced. The later cast iron cranks used a 2 inch wide harmonic balancer and torque converter balance weights. Hope this helps.
67charger64
Jun 30, 2015 04:49 PM
cfryerson
Aug 21, 2009 07:56 AM
bighammer
Apr 6, 2009 05:02 PM
6865coronet
Jan 29, 2009 02:33 AM
cfryerson
Jan 5, 2009 06:39 PM
