46RH direct drum machining
Old Mar 27, 2020 | 02:40 PM
jeepers creepers's Avatar
Hi guys, i'm on the process of rebuilding a 46RH came out of a '94 Jeep ZJ, i found that the band was actually without any friction material left and was working metal to metal on the outer diameter of the drum so of course , it caused some wear on it, it has grooves but the thing is concerning me the most is that there's a little bit of taper on the end of the drum itself, didn't have the chance to measure it yet.
I'm thinking to put it on the lathe but i have no idea what the minimum diameter would be. I know that band preload , must be set with the torquewrench, so there's no problem if diameter is a lil smaller and having the drum a relatively big external diam. band can still perform well anyway.
Opinions wanted. Thank you for your time.
Old Mar 27, 2020 | 08:33 PM
Give it a Shot....
Old Mar 28, 2020 | 02:17 AM
Give it a Shot....
Hi, you meant to machine it?
Old Mar 28, 2020 | 08:02 AM
Don't use it for target practice just yet.
Old Mar 28, 2020 | 09:42 AM
Yes.... Then put it back in the case and see if the band will adjust. But test it before you put it back together....
Old Apr 10, 2020 | 08:16 PM
64Cudammando's Avatar
Pitch it. There's one on ebay $33.99 free shipping.eBay item number:
202559593759
a.johansson84
15
Aug 12, 2012 07:08 AM
73_Duster
Jul 12, 2011 09:31 AM
first64dodge880
Sep 28, 2010 10:34 PM
66dartvert
Mar 17, 2009 02:38 PM
afastcar
Dec 18, 2008 04:15 PM
