727 Build Up
Old Apr 4, 2014 | 11:11 AM
streak_06's Avatar
727 Build Up
Trans is in a 68' Satellite which I'm hoping to be pushing 400 at the crank. What are the best improvement that can be done to the 727 trans so that I'm not constantly breaking it. BTW it needs to be rebuilt anyways so figured that I would beef it up a little during rebuild.
Old Apr 4, 2014 | 11:38 AM
moe7404's Avatar
iam not a trans expert. but i found am EXTERNAL filter.
man o man i about forgot yes its a cut & past sorry. __________________
after you clean the trans. add this to your*chrysler*trans. an external fluid filter
1. go to auto-zone. get 2210, its called a power steering filter, but it is for transs to. it is for 3/8 tubing. by (magna-fine) be sure to use high pressure hose. Reff:http://www.magnafilter.com
2. for other sizes wix 58964 5/16 tube size
Old Apr 4, 2014 | 12:14 PM
400 hp Just a good rebuild and a shift kit
Old Apr 4, 2014 | 05:48 PM
Yep.... Call and get your stuff from John Cope.... http://coperacingtrans.com/
Tell Him I sent you....
Old Apr 5, 2014 | 10:18 AM
streak_06's Avatar
Ok i will check out the website and see what i find thanks RacerHog
Old Apr 5, 2014 | 08:34 PM
Just remember the Throttle pressure linkage that hooks to the carb IS VERY IMPORTANT. Most 4bbl conversions do not get hooked up correctly USE THE CORRECT PARTS and correct throttle arm for your aftermarket carb !!!!!!
Old Apr 5, 2014 | 08:46 PM
I discovered, quite by accident, after buying one on Craigslist, that I just absolutely LOVE all manual valve bodies!!! Jus' thought I'd throw that out there!!! You can "throw one in" easily, and if you don't like it, "throw it back out" in an afternoon. Don't need a kickdown.
Old Apr 6, 2014 | 01:53 PM
pro-tech's Avatar
Cheetah by Turbo Action makes a full manual valve body in either forward or reverse pattern for about $270 it does not have a kick down linkage also if you down shift it will only hold back in second gear...If you shift back to 1st it free wheels like neutral until the RPM catches up with the trans. speed....Like 440 said it is the best I love it...Bill
Old Apr 6, 2014 | 07:55 PM
inri's Avatar
I just replaced my B&M manual trans kit with the Turbo Action Cheetah Pro valve body. What A HUGE difference!!!
It's like the transmission woke up! Best valve body!!!
pipdog69
Mar 13, 2012 11:01 PM
TKK
Aug 10, 2011 06:45 PM
deadkelly
17
Jun 12, 2011 04:27 PM
TCPMeta
Apr 3, 2009 06:52 PM
rubadub
Nov 11, 2007 02:02 AM
