727 lock up converter?
How to tell if a 727 has a lock up converter? I read on Allpar.com that in 1978 Dodge started making lock up converters for the 727. That is something I would like to have in my 76 W100. Im having some leaking problems with my 727, I have my 727 out of the truck right now and am thinking about having it rebuild. I know of a 78 Powerwagon parts truck that has a 727 in it. On Allpar it says that you can identify a lockup 727 because it has about 5/8 of a inch of the end of the smaller input shaft machined smooth. If the splines go out to the end of the shaft , except for about 1/8 inch bevel, then it is a non lockup 727. Im not sure what shaft they are talking about. Does anybody know what shaft they are talking about?
That is not true as the only difference between the 2wd and 4wd trannies are the tail shaft housings. Depending on when Dodge introduced the lockup 727, you may or may not have one. If they introduced it in 1978 as mentioned before, then chances are fairly good that you do not have a lockup unit (unless someone swapped out the original tranny for a later model unit).
The Jeep J-series trucks also used the 727 tranny behind the AMC inline 6 and V8 motors and some were lockup. I know this as I pulled a 727 lockup from a 1987 J10 with an inline 6 and it was 4wd.
crwchf16
Feb 3, 2014 07:17 AM
Belair
Aug 4, 2013 09:08 AM
