727 snap ring pt# 2400320
Jun 16, 2014 | 04:25 PM
I am looking for a NEW snap ring for my 727.
This snap ring goes on the front end of the output shaft and holds the front planetary to the output shaft.
The dimensions are approximately id >15/16" x 0.077 thick.
I have tried 3 local transmission shops for a used one, to no avail so far, but I still have a couple yet to try for a used piece.
I would prefer a couple new ones if at all possible (manufacturer or brand not important).
Thanks
Peter
Reply 0
Jun 16, 2014 | 06:13 PM
Peter, let me look when I get back home on Friday... May be slightly used but will see and let you know....Mack
Reply 0
Jun 17, 2014 | 07:20 AM
I'm Out.... If Mack Don't have any?????
Cope Racing Trans or A&A Trans Should fix you up...
Reply 0
Jun 17, 2014 | 01:05 PM
I think the thickness is the oddity of the snapring.... I will check on Friday....
Reply 0
Jun 20, 2014 | 09:15 PM
try A & Reds in Wichita KS. http://www.areds.com/ i have known these cats since the late 60s. if they dont have it NO one will.
Reply 0
Jun 21, 2014 | 09:39 AM
Thanks guys
I found a supplier "rotorclip"
Cheers
Peter
Reply 0
