727 snap ring pt# 2400320
Old Jun 16, 2014 | 04:25 PM
Drag Pak's Avatar
727 snap ring
I am looking for a NEW snap ring for my 727.
This snap ring goes on the front end of the output shaft and holds the front planetary to the output shaft.
The dimensions are approximately id >15/16" x 0.077 thick.
I have tried 3 local transmission shops for a used one, to no avail so far, but I still have a couple yet to try for a used piece.
I would prefer a couple new ones if at all possible (manufacturer or brand not important).
Thanks
Peter
Old Jun 16, 2014 | 06:13 PM
Peter, let me look when I get back home on Friday... May be slightly used but will see and let you know....Mack
Old Jun 17, 2014 | 07:20 AM
I'm Out.... If Mack Don't have any?????
Cope Racing Trans or A&A Trans Should fix you up...
Old Jun 17, 2014 | 01:05 PM
I think the thickness is the oddity of the snapring.... I will check on Friday....
Old Jun 20, 2014 | 09:15 PM
moe7404's Avatar
try A & Reds in Wichita KS. http://www.areds.com/ i have known these cats since the late 60s. if they dont have it NO one will.
Old Jun 21, 2014 | 09:39 AM
Drag Pak's Avatar
Thanks guys
I found a supplier "rotorclip"
Cheers
Peter
68 Sat
Apr 25, 2011 07:02 PM
thedusterridesagain
Mar 7, 2010 03:57 PM
sgp7679
Aug 25, 2009 04:44 AM
jar84203
May 13, 2009 03:04 PM
67 Coronet
Nov 5, 2007 03:07 PM
