727 Trans wont go into gear
Old Apr 16, 2017 | 12:36 PM
JPR56's Avatar
Hey Guys
I'm new to this forum and looking for your help
I just got a 1936 Plymouth P1 with a 1968 Charger 383 Magnum bored 30 0ver with a mild cam and a 727 trans. Took it out the other day to a friends and when I went to start it it would not go into gear. towed it home and adjusted the linkage but now only have Park, Reverse, Neutral and 3rd gear it kind of whines in first and second but will not move. Oil is fine.
Any suggestions.
Old Apr 17, 2017 | 09:38 AM
Drag Pak's Avatar
The front and rear bands are so worn/out of adjustment they will not hold? Drop the pan and check. The oil pump is worn out? Either way, it sounds like a major!
Old Apr 17, 2017 | 05:51 PM
I agree... Sounds like the T.V. Linkage was out of adjustment and took out the clutch's...
Not a good sign.. Sounds like Overhaul time...
Welcome to the site.... Keep us posted on how you turn out...
Old Apr 18, 2017 | 06:10 PM
JPR56's Avatar
727 trans wont go into gear
Awesome, Thanks for the replies, it exactly what you said. Total rebuild
Thanks for the help
Awesome site
Jim
Old Apr 19, 2017 | 06:11 PM
Keep us posted on how it works after you get it all fixed....
Jeff Olenski
Sep 5, 2016 05:03 PM
sm73charger
Sep 10, 2015 10:03 AM
AllyRat31
Jan 27, 2015 09:38 AM
krublee
Jan 2, 2011 11:02 AM
staledog
Oct 13, 2010 08:10 PM
