727 won’t work....grrrr
Hoping for some helpful advice....have a ‘68 Sport Satellite that I benched a few years ago to build. It now has a 440/727 combo, had tranny built (stock, no shift kit) by the local shop here in Missouri. Once installed and engine fired, tranny wouldn’t shift enough to drive around the block....fluid level okay, checked in neutral when warm. Trans pan gasket start leaking, so I replaced the cork gasket from the tranny shop with the Mopar rubber gasket and refilled with 3 quarts fluid as recommended. Had to keep adding and adding fluid for the thing to finally register on the dipstick, still wouldn’t shift into gear properly...move the column shifter into PRN123 and wiggle around until it caught, then would fall out of gear. Jacked car up and checked linkage adjustment....seemed okay. The next morning the shop floor is covered in ATF as the trans puked its guts of excess fluid, I guess....checked the fluid level after mopping up the mess and it’s right at the full mark. Started the car and it won’t shift into any gear. The only thing I can do is take it back to the tranny shop ( major hassle), but was wondering if there was any advice on something to check, or something I missed. Thank you
1. What is leaking now ans where?
2. This car has all the rite linkage for a 440 and a 727 trans? Rite !!!
If you filled the trans when warm, in neutral, and the sick read full. The the trans has what we call 'Morning Sickness" all the fluid drains from the converter back into the trans. Thats a hard part issue...
Lowflyer17z
Aug 12, 2015 10:32 PM
christineman
May 24, 2012 06:44 PM
Steven Bowers
May 9, 2010 01:10 PM
