727 won't upshift 1-2 or 2-3 without lifting throttle?
Old Sep 29, 2019 | 10:54 AM
droptail's Avatar
Hi!
Been working fine 1.5 years ( except for 2-3 flareup below) and out of the blue I went to return home after 1 hour cool down and it wouldn't upshift (1-2 & 2-3) until I lifted throttle.
Linkage & throttle lever shaft function looks correct.
Fluid level good. First & reverse fine.
history: 40k mi on rebuild 35 years ago.
Transgo shift kit 1.5 year/5k miles ago. never got rid of a (mild) 2-3 flareup subsequent to kit install.
I plan on going over the linkage adjustment again, then dropping pan to take a look see.
Any ideas?
thanks
Old Oct 1, 2019 | 05:59 AM
Something is not rite for sure... Flairup should have went way with the shift kit. Also Reset the band adjustments if you have not done that yet.
Old Apr 10, 2020 | 08:23 PM
64Cudammando's Avatar
Sometimes the return spring for the kickdown rod gets weak or breaks or falls off.
gearheadmike
May 4, 2017 05:22 PM
koondawg_74 roadrunner
Jul 22, 2012 06:51 PM
chicisles
Jun 14, 2012 03:19 PM
Chadderbox74
Apr 19, 2010 02:45 PM
Vaugh22
Aug 27, 2009 04:33 PM
