89 D150 Converter wont lock up
Old Aug 2, 2013 | 06:58 PM
Belair's Avatar
Rebuilt valve body and new lock up solenoid that is on valvebody.
Could speed sensor be a part of the problem or something else?? Or am I replacing the converter...?
Old Aug 2, 2013 | 07:19 PM
Check for a TCC Fuse...... Also check the OD in and out switch and make sure it's working.
Old Aug 3, 2013 | 09:00 AM
Belair's Avatar
89 D150
Where would the TTC fuse be? All my fuses are good. I had a 91 that had the OD button on dash. This one does not...
Thanks.
Old Aug 3, 2013 | 03:00 PM
Oh...Your has the "D" with the circle around it?
Could be the speed sensor.
Check to see if it's getting Signal... Should come from the Computer.
Old Aug 3, 2013 | 03:30 PM
Belair's Avatar
Doesn't even have that.... But It does shift to 3rd but no lock up.
3.50 gears. But shouldn't be screaming at 65,0....
Old Aug 4, 2013 | 09:08 AM
Belair's Avatar
Vin states 4 speed overdrive.....
crwchf16
Feb 3, 2014 07:17 AM
04 Diesel
May 12, 2013 05:41 AM
78cordoba
Sep 23, 2009 04:39 PM
64fury
Mar 6, 2008 06:57 PM
ppkaprince98
Feb 5, 2008 12:07 AM
