dana 60 info
Old Jan 20, 2012 | 07:15 PM
birkey's Avatar
dana 60 info
Anybody know ring and pinon gear setup in a 1998 ram 2500. i think i read 4:11
Old Jan 20, 2012 | 07:50 PM
Archer's Avatar
birkey -
No idea
Block the front tires, jack up the rear, put the tranny in neutral and spin the rear wheels. Count how many revolutions the tires make relative to the drive shaft.
There are also charts to give you the rear ratio based on rpm and mph.
Old Jan 20, 2012 | 08:20 PM
If it is like my 98 Van The gear ratio will be listed on the info sticker under the hood..
Old Jan 23, 2012 | 02:41 AM
As long as someone hasn't removed the tag, there is usually one between two of the cover bolts.
If you have a 5.9L gas motor, then you will most likely have 4.10 gears. You can always pull the cover and read what is printed on the ring gear. They will say something like 41-10 (if it is a 4.10 gear ratio).
phatdak18
Jan 3, 2009 07:57 AM
edwin 440
Nov 18, 2008 05:19 PM
mopar nate
Nov 11, 2008 01:14 AM
71charger
Apr 2, 2008 05:22 AM
499coronet
Feb 18, 2007 12:48 PM
