Dana 60 rear change
Old Feb 20, 2012 | 10:08 AM
michuy's Avatar
Dana 60 rear change
Greeting to all,
I have a 72' d200 with a 410 rearend gear ratio. It's great for the occasional metal recycling hauling with my trailer that I do (and for burning-off a little tread now an then). But I only do this (hauling) parttime, mostly I spend about 85% of the time on the hwy. The trade-off is that I'm running higher RPM's at "less comfortable" cruising speeds out on the hwy. Lower mpg's is a big factor as well. My question is how much of a benefit would I get by going to a 355 or even lower rearend ratio as far as rpm's/mpg's? Thought about an A518 and having the best of both worlds but it's a cheaper and less involved route to go with a rearend ratio change. Thanks
Old Feb 20, 2012 | 10:12 AM
In my Dakota I run a 3.90 suregrip with the A518 overdrive tranny. I pull 2400 rpm at 70 mph. Changing yours to a 3.55 or 3.23 would be a great increase in mpg for you.
Old Feb 20, 2012 | 10:34 AM
michuy's Avatar
Thanks Bremereric,
Just curious, did use the non-electronic A518 and go with the PATC conversion kit? Or did you find your own solution for your particuliar application?
Old Feb 21, 2012 | 05:17 AM
3.54 is the lowest that you can go with a D60. The design of it doesn't allow for any larger pinion gear head to fit properly.
A hydraulic OD tranny would help out greatly.
Skynyrd
May 20, 2015 04:27 AM
98 SNAKE EATER
30
Jun 14, 2013 06:16 PM
70HemiRR
Jun 20, 2009 09:25 AM
mopar nate
Nov 11, 2008 01:14 AM
499coronet
Feb 18, 2007 12:48 PM
