Differential oil
Old Sep 13, 2018 | 03:59 AM
SixBanger's Avatar
Differential oil
Hello!
I have a question. I want to replace the oil in the differential of my Volare. I searched the internet to find out what a suitable oil is. But I saw that this depends on the differential. The only thing I can say about the diff type is that the cover is a 9-bolt hole variant (Chrysler, 7.25 ").
On the internet I have found that 80W90 is sufficient. Can someone tell me if it's the right oil? Are there other addictive needs?
Thanks
Old Sep 13, 2018 | 05:37 AM
That should work just fine...... However if the differential has some slop in it? I would go with a Torco 140 weight but that also depends how cold it get were you are at.
Old Sep 13, 2018 | 06:48 AM
SixBanger's Avatar
Thanks Bob. I would put some 80W90 oil in it. In winter it is here not as extreme cold in the Netherlands. At least -10 degrees Celsius.
67Polara
Aug 8, 2010 03:29 AM
dzltd02
Oct 28, 2008 08:25 AM
mukky
Aug 7, 2008 09:39 PM
oilplanet
Mar 29, 2008 11:08 AM
